-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Checking automatic trans fluid.. Where? (http://forums.pelicanparts.com/porsche-928-technical-forum/310912-checking-automatic-trans-fluid-where.html)
RadioDjKev 10-21-2006 04:42 PM
Where do I check the automatic transmission fluid level on a
1986 Porsche 928 automatic??
Also do I check it running or not? warm or cold?
Thank you for all your help.
I love this website. :)
Kevin:rolleyes:
IXLOR8 10-21-2006 08:54 PM
I have a three speed auto. Check fluid hot. My car has a small tube like device on the passenger side. It is on the transmission.
I do not know if the`3 and 4 are in the same location, but it's worth a look.
jstobo 10-22-2006 08:38 AM
For 85-86 you check it and fill it at the transmission. On the passenger side there is a plastic tank that you check the level . Easy with a lift. Pain in the ass otherwise.
RadioDjKev 10-22-2006 10:30 AM
Thank you,
I will get to it right after the San Diego Chargers game.
m21sniper 10-23-2006 12:57 PM
Its under the middle of the car, on the pass. side.
RadioDjKev 10-23-2006 02:32 PM
Yeah I found it. Thanks. I rasied the car up level on off all 4 wheels,
and it is level. Should I check it while it's running and warm?
I do not have an owners or shop manual.
Thanks, Kevin
m21sniper 10-24-2006 03:35 PM
Running and warm.
RadioDjKev 10-24-2006 03:58 PM
Thank you! :)
m21sniper 10-24-2006 04:27 PM
Its why i'm here bro.
