928 tire pressure
what kind of tire pressures are you guys running. The manual for my car says 36 psi front, 44 rear. I have been running 32 psi front and back.
I recently tried upping my tire pressure to 36/44. Let me tell you about it. with 44 psi in the rear, the back stepped out on me in a wild fashion, resulting in a spectacular spinout. I am trying to fix the small crack in my front spoiler now as a result of a little off road excursion.
In my opinion, If you like the feeling of driving on wet pavement when it's dry, try using 44 psi on your rear tires.
Now my tires are back to 32 psi front and rear
Old 04-05-2007, 11:43 AM
Heavy Metal Relocator
rhjames's Avatar
depends on tire size and manufacturer's guidelines.
if your running anything close to the stock tires sizes (16's), your 32lbs is probably fine, certainly no more that 35lbs.
more than that, and you'll burn up the center of the tire tread area.
less than that, and you'll eat up the sides.
it's that easy....
good luck.
regards---rhjames
19x8, 235/35/19 front
19x11, 315/25/19 rear
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 04-05-2007, 09:34 PM
Network Native
Danglerb's Avatar
Lots of cars suggest a higher than normal pressure for high speed driving, maybe Porsche just assumes thats what you are doing?
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 04-05-2007, 09:55 PM
