immobiliser wiring
I have an H&P immobiliser ( PWB labeled as 1992) which has been disconnected from the car by cutting through the thick black wires. I am able to open the unit, so I can trace the wires to their destinations. Does any one know which is which? in particular the power in and ground. The key wires are un damaged.
Old 04-10-2007, 05:34 AM
H&P immobiliser? How about some electrical schematics or pictures, a website to H&P immobiliser?
Last but not least! What car are you working on; we need Model and Year?
Cheers, T_MaX
89 S4, Auto-box, Silber/Blue, 320ish RW HP/TQ
Old 04-10-2007, 10:36 PM
H&P make the OEM immobilisers for several manufacturers including porsche, and typicaly they work on several circuits simultaneously. They are very well engineerd , housed in a welded steel box and silicone potted into the box. In the case of my example the silicone didnt bond to the case that well, and I was able to eventualy prise the whole free with out damage. My car is a Euro spec S2, but given the immobiliser is dated '92, and the car was made in 84, it has to be a retrofit. The key socket is still available from Porsche. I'll adda picture this evening... Mind I might also attack the circuit with a meter and work out what is what the hard way. It all depends on the kids going sleep.
thanks,
John
Old 04-11-2007, 01:10 AM
John, are you British? The only reason I ask, is that what you call an H&P immobilizer, here in the states maybe called something else. I’m looking forward to your pictures.
Cheers, T_MaX
Old 04-11-2007, 09:12 AM
The three black wires centre picture are the area of interest, the right wire is connected to what I take to be the ground plane, the left and centre are i think power in and ignition fed power to hold the device on when the motors running. I have tracked the remaining wires to individual relays.
sorry its taken so long to get the pictures sorted.
Old 04-25-2007, 01:31 AM
