What I found with Your Help!!
Well all with all of your help I have just about gone through all of the front of the car. This is what I found and I would like to thank everybody that took time to help!!
1. Rotor and Cap OLD.....plugs not too bad.
2. Belt lose on the cooling fan
3. Heater Valve not holding Vac.
4. Vac. line from Vac. advance to Throttle body off and just hanging there. I believe this one also operated the fuel pressure regulators.
5. O2 sensor unplugged....do not know why yet since I have not had it out of the garage, but they left the two small wires plugged in and unplugged the big one???
6 Cig lighter working (need my Escort r/d in this car) fuse
Next weekend we are changing the tranny fluid and filter and chasing down a Clunk when she shifts??
Thanks to all once again.
Brian
Old 06-05-2007, 03:12 AM
Network Native
Danglerb's Avatar
Fluid and filter fix a lot of minor issues.
My cigarette lighter doesn't seem to fit anything I have tried to plug into it, too short I think. You may need to hardwire the escort or at least an extra cable.
Everybody loves the MightVac, and apparently needs such a device to troubleshoot. Replacing all my vacuum lines with silicone hose is on my list as soon as I decide who to buy hose from. Carl has a kit on ebay for the 928 for about $33, but it doesn't look like enough hose to me.
Your PO sounds like a real gem.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 06-05-2007, 12:24 PM
Heavy Metal Relocator
rhjames's Avatar
wonderful news!
suggestion:
don't bother with the Escort, instant-on (or laser) will get you every time........if you must, Phazar is the trick unit, or at least one of the high end BEL units.
others will argue this, but we know........
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 06-07-2007, 06:36 PM
Our area is pretty poor...... The 8500 has been excellent for all of our trips from Ohio to Hatteras and little trips. Does anything under a thousand really work with laser. My problem is portability we switch from my Wife's 525i to my Suburban ( ss 454 project) for trips so a hard wired unit does not work....Now we have this stuff ironed out.........going to do some touring in a Porsche!!!
Brian
Old 06-08-2007, 01:51 AM
Network Native
Danglerb's Avatar
Nice looking car Brian.
www.tixnix.com, Valentine V1, and I think Escort 850? I work hard at driving insanely within legal limits, so don't use one.
Old 06-08-2007, 12:46 PM
928 OB-Wan
Rixter's Avatar
love that color Brian, your ride height needs to be reset, or you took the pic just after you got it back on the ground
78 928 Euro 5spd #34
88 928 S4 AT NachtGrun/GrauGrun
88 928 S4 5spd Guards Red/Black
12 Volvo C30 IceWhite/Black
Old 06-08-2007, 01:02 PM
How do you reset the ride height?
Old 06-08-2007, 02:33 PM
Network Native
Danglerb's Avatar
928 is sensitive to ride height, many like to "mess" with it, lowering it from stock is generally a bad idea, but there is a range that seems OK.
If the car gets jacked up with the load removed from the wheels, it takes more than 10 miles of driving to get the suspension settled again. So if you have done it recently, just wait for it to settle.
BTW put the model and year into in your info, I keep forgetting what it is. Looking for a link to setting ride height, but its basically measured from a couple of suspension points to the ground and adjusted with threaded collar on the shocks.
Old 06-08-2007, 03:49 PM
Network Native
Danglerb's Avatar
Here is a good link
http://www.928.org.uk/mambo/index.php?option=com_content&task=view&id=57&Itemid=43
Old 06-08-2007, 03:58 PM
Thanks for the info.....I believe it settled back down after a ride around the block.
Mine is a 84 automatic.....
Brian
1984 928 Auto
2001 525I
1996 Suburban 2500 454ci
Old 06-08-2007, 05:08 PM
