-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Outer C/V joint (http://forums.pelicanparts.com/porsche-928-technical-forum/351539-outer-c-v-joint.html)
Brian Felts 06-11-2007 04:23 PM
Outer C/V joint
Hey all I was chasing a squeeking in the rear and found my passenger side C/V book busted. I believe the squeek is coming from the same spot.....is this a hard job?
I have read info that says busting the outer 32mm and removing the bolts from the tranny flange and it just comes out..is this true? How hard is it to replace the outer joint on a 1984?
Brian
