pass mirror glass, glue?
anyone ever glue the mirror glass on one of the side mirrors?
just wondering if anyone can recommend a good product
Old 05-13-2010, 01:37 PM
Maleficio's Avatar
Probably the same epoxy you'd use for the rearview mirror.
Old 05-13-2010, 02:41 PM
bwmac's Avatar
Yes and know, I believe at the dealer we were using a contact cement to glue the back of the mirror to plastic. But when you are glueing glass to glass or steel to glass then that special Krazy glue, for glass, bought at the auto parts store is the best.
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 05-13-2010, 05:19 PM
Network Native
Danglerb's Avatar
The side glass mirror, mine at least, has a plastic heater thing on the back with 3 spring clips. The whole assembly is something like $65 for a factory part, no clue on just replacing the glass from a glass shop etc, but I would use some kind of "mirror" adhesive to stick the new glass to the old plastic heater thing.
Old 05-13-2010, 11:18 PM
Xlot's Avatar
The glass came off on my right-side mirror - I saw it moving (was being held on b y surface tension of moisture - it slid down as I closed the door one morning and when touched, came off in my hand).
I glued the glass bit back onto the plastic backing (which has the heater element in it) using a construction adhesive called Liquid Nails - glues pretty much any surfaces, and is good for outdoor temp ranges and moisture resistance.
Various manual S4's
Old 05-14-2010, 02:39 PM
Linderpat's Avatar
I have done this and just used a thin smear of gorilla glue. Works perfectly, no bleed thru, and never lets go.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 05-15-2010, 08:49 AM
Maleficio's Avatar
PO knocked the driver glass out by smacking it against the garage door jamb. Good driver, eh?
So he glued it back on, but didn't support the glass as the glue cured, so the glass slid down to the bottom of the housing, and now cannot be adjusted because it's jammed. I want to remove it and re-glue it, but I'm cautious about breaking it in the process.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-15-2010, 09:55 AM
i ended up using a whole tube of that 2 part epoxy, that comes in a hypodermic looking duel tube. it looks like a big needle with 2 tubes attached. so far so good
Old 05-19-2010, 05:10 PM
