-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Chips from RPM Performance? (http://forums.pelicanparts.com/porsche-928-technical-forum/355661-chips-rpm-performance.html)
mtelliott 07-05-2007 08:43 AM
When I bought my car (1985 928 S), it came with a two chips from RPM Performance. What are they (besides computer chips)? What were they intended to do from an engine management standpoint?
I tried a quick google and couldn't find anything on what specifically they were designed to do.
Anyone?
Michael
Danglerb 07-05-2007 10:32 AM
I don't know them specifically, but "suspect" they are pretty much a copy of the Auto Authority type chips. The chips themselves are I believe just a normal eprom like a 27c32, one goes in the ignition brain to make the timing a bit more agressive, and one goes in the injector brain to change the fuel/air table. Factory settings in 85/86 were very conservative going for best MPG and lowest emissions.
Most people report a nice increase in power and responsiveness with the chips, but sometime you need to pull them to pass a smog check.
Before plugging them in you should get a more informed answer on your specific chips first. Given how cheap a known good set of chips are these days I would get some that have been freshly burned and checked.
BTW its not unusual for a new owner to find a box like you have actually contains the factory chips and the hot rod chips are already in the car.
mtelliott 07-05-2007 10:40 AM
Great advice.
I actually only know what the chips are due to the label on the actual chips.
I'm guessing that with a more aggressive timing, I would need to step up to running premium fuel. For now, I'm interested in fuel economy (this will be my daily driver (60 miles roundtrip).
porken 07-05-2007 05:34 PM
I have those chips in my '86.5. The ignition chip gives the most benefit, the fuel adds a little up top, but overfuels somewhat on acceleration.
A good setup is the performance ignition with the factory fuel chip. If you are not driving too aggressively, you could use Plus, especially if you plug in the octane loop.
The factory was conservative on the ignition because there are no knock sensors, and they were concerned about the quality of unleaded gas available at the time.
Herr-Kuhn 07-05-2007 05:42 PM
At this point in 928 development, you woudl be best ot get your hands on a Shark Tuner and write your own chip set. Then they are matched to your car and it is exactly what you want it to be.
Danglerb 07-05-2007 06:46 PM
This is pure speculation on my part, but for a stock 85/86 928 and with some allowance for variation in gas quality, how far apart is a sharktuner chip and a generic chip?
