-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   oxygen sensor (http://forums.pelicanparts.com/porsche-928-technical-forum/358209-oxygen-sensor.html)
jim ross 07-20-2007 06:36 PM
oxygen sensor
I am installing an air fuel ratio meter....in my 84 928 S, i have located the leads to the oxygen sensor...two wire connector--the heater wire? and thick green wire---signal wire to computer? i believe i should tap into the green wire..BUT, i am getting no power to any wire, with key turned on. ( engine not running) PLUS the green connector was broken and disconnected too when i found it!!! can anyone shed some light on this dilemma? thanks JIM:confused:
Danglerb 07-20-2007 07:04 PM
Its good to lay out all the details of what you are installing, as it may have issues that are known. Which meter, sensor, etc.
