-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   32V'r 928 cam timing tool (http://forums.pelicanparts.com/porsche-928-technical-forum/359698-32vr-928-cam-timing-tool.html)
porken 07-30-2007 11:34 PM
I make these in batches, and I need a few more orders to pay for the laser cutting (I have to order a min. of 10). This may be the last run!
Easily check and adjust your valve timing, or just install a new cam gear. Most 32V are out of adjustment!
Much easier than the dial indicator WSM method, and you don't have to remove the cam covers.
http://liftbars.com/images/32VrSystem.jpg
click for more/order info
Danglerb 07-31-2007 12:54 AM
No more will be made?
Whats up Porken?
porken 07-31-2007 10:51 AM
I get fewer and fewer orders each run.
BTW: I've got (3) conversions left for converting 16V cam gears to adjustable 32V gears - the 16V'r. I am not going to make any of those any more.
tdelarm 07-31-2007 11:58 AM
How's that sweet Porken tensioner doing on the your white 928 you displayed at Shanes last year? It looked great.
Tim
porken 07-31-2007 01:07 PM
Tim,
I went through a whole pile of prototypes (& $$) since then, but the production version is up and running on a handful of cars now. I making it in two versions, with and without the airpump.
http://liftbars.com/images/PKsnrModels.jpg
click for more info
Danglerb 08-01-2007 10:44 AM
Right now I have only 16v plans with cams installed straight up, do these apply to my needs or are they just for cam masters (people with advanced degrees)?
porken 08-01-2007 12:35 PM
Unless you are lucky, the 16Vs are never quite at zero. And there's no way to dial in some retard for the 1-4 side to compensate for hot-engine-expansion-advance.
hughett 08-11-2007 09:15 PM
I bought and have used PorKen's 32Ver tool and I now consider it a must-have for the serious 928 tuner.
Harvey
