-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   "dinging" won't stop (http://forums.pelicanparts.com/porsche-928-technical-forum/362790-dinging-wont-stop.html)
Mat 71 08-19-2007 05:23 PM
Hey guys,
yesterday I was driving and the power window fuse blew, and possibly the cigarette lighter fuse. The red warning light on the dash started to flash and 'ding'. I pushed the warning light which turned it and the dinging off. All seemed well.
I got home and replaced the fuses and started the car and dinging won't stop. The warning light is not flashing, and no other fuses are bad (that I can see).
I also took the positive off the battery hoping to 'reset' the system. Still dinging. Maybe I need to take the positive and the negative off?
Has this happened to anyone. Any thoughts on what to do?
Thanks in advance.
Mat
Danglerb 08-19-2007 07:45 PM
Maybe you have a shorted wire, check for an abnormal drain on the battery (engine and key off, put an ampmeter between the battery and the ground cable).
