Where can I buy a/c fitting for 928 S4?
I want to recharge the a/c on my 1988 928 S4, but noticed that it has an unusual fitting where the refridgerant is added. Do any of you know where I can buy the adapter so that I can add refridgerant to the a/c system?
Old 09-25-2007, 08:28 PM
Herr-Kuhn's Avatar
It should be a standard R12 fitting...if the car has been converter it will be an R-134 fitting. You should determine what you have first. The proper way to conver to 134A is to change the expansion valve, dryer and then flush it out and refill with 134 A and compatible oil. You can't mix the two gasses.
Any decent auto parts store can get you those fittings...but be careful, never attept to charge through the high side...all gas should go in on the low side and you should really vac it down first.
Kuhn Performance Technologies, LLC
Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane.
Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane.
Old 09-25-2007, 08:33 PM
