Will this rim size work?
I am not completely up to date on my rim sizes. Will the following 'Twists' work on my '83?
7x17 ET 55 (part # 986.362.124.00) and 8.5x17 ET 50 (986.362.126.05). Any help is much appreciated! M.
'70 911T - my first - SOLD '83 928S - fast becoming the daily driver - SOLD '03 Ford Explorer Eddie Bauer - wife '03 Cadillac CTS - daily 1990 928 S4 |
A Wrench
Yes, the ET 55 will work both front and rear.
If you want to push the rears out some, a 17mm spacer will work w/o having to roll the fender. You can put a 21mm spacer in there, but I would advice rolling the inside of the fender. On the spacer subject, you have to get the hubcentric spacers. Best bet is to get them with the bolts already installed, not the 5 hole ones. If you have to get them w/o bolts, plan on taking your hubs off, getting the 72mm bolts to install as you do the wheel bearings et al. |
Thanks for the advice.
All the best. M.
Heavy Metal Relocator
if you have further questions about wheel fitment, I suggest you contact Carlos @ Wheel Dynamics in Los Angeles....
extremely knowledgeable, knows what works and what doesn't. -----------------
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
