Garage: Yes but no roof.
Air pump out/in thanks everyone!
Job done: replace air pump:
Time: 3 hours (newbie)
What: fried air pump. Not working anymore => no radiator fan cooling (share same belt).
How: http://members.rennlist.com/sharkskin/Pages_SA_R06-SharkBitesBack-AirPump.htm
Thanks to Russ for the air-pump he no longer needs (pulley).
Sharkskin's write-up is great, easy to follow. Improvements:
Didn't need to remove/move the air filter. Removing the fan housing provided enough space to remove the air pump. Getting it out was more difficult than getting it in.
Moved heat-shield from my old pump, as it was still fully intact.
Picture showing the old pump out (usefull for reference on how the pipes should be aligned).
Remaining question/uncertainty: The airpump filter is not attached to anything else. Is this normal?
Next week: Replace radiator (also spare parts Russ - thanks).
BIG thanks to you all for advice etc.
Pelican friend in France: Pauwl
p.s. Russ, if you're wondering why I needed the radiator & condenser, see picture below.
Old 10-26-2007, 01:31 PM
Heavy Metal Relocator
rhjames's Avatar
Excellent Pauwl!!!!
very glad I was able to help!!!
yes, I can see why you really needed the radiator too---that looks nasty.
if there is anything else I can help with, please let me know.
regards---Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 10-26-2007, 08:26 PM
rhjames's Avatar
air pump filter hose is the only thing attached to the filter canister---no sweat.
You're doing fine!!!
---Russ
Old 10-26-2007, 08:28 PM
