Garage: Yes but no roof.
Suspension: Should it look like this?
While replacing brake discs & pads, I jacked up the car both sides.
Can anyone tell me if this is what I should see (car on stands)?
The plastic 'thingy' around the suspension shaft is chipped on the right wheel side. Left wheel side looks similar, but no chipping.
Anything wrong here, or just normal wear?
thanks,
Pauwl
'84 928S (Euro) Automatic Shiefferblaumetallic
Old 12-03-2007, 06:57 AM
Originally Posted by John Taylor View Post
Just a fiber stop washer, no big deal. They're cracked/broken on most Porsches. They cost over $10 new (if you can find them), and you have to pull the shock/spring assembly and disassemble the whole unit in order to replace it. I think the part number is 911.333.511.00. They're new and still intact on mine because the assemblies are about one year old, but they were cracked on my other cars. Nothing to lose sleep over, just normal wear.
Thanks John, I'll get on with the other stuff first now.
Pauwl
Old 12-03-2007, 07:44 AM
