callmethewander's Avatar
almost blew my head off!!!
I went to look at an '86 928 today that hasn't run in a couple of years, the owner said it was running fine but he had not been using it so only started it occasionally until once when it did not start. He bought a 968 and was living out of town so the car was just sitting for close to a couple years now. Well, of course it wouldn't start so we opened the airbox and i sprayed in starter fluid as the owner cranked the engine, it seemed to almost start several times until, as i was spraying in the starter fluid... BOOOM!!! I am not kidding the sound deafened me and sent me backwards. When i moved back to look under the hood, both of the air inlet boxes on the sides of the intake manifolds had blown completely off at the place where they clamp onto the the intake pipes, the insulation from the hood was blown off and all over the place, a small pipe at the back of one of the side airboxes was broken off, and i was completely disoriented. What the heck could have happened? anybody know?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 02-19-2008, 05:06 PM
A Wrench
SeanR's Avatar
Hot wire and flammable fluids don't mix. Not a good idea to do this
'88 Supercharged and lots of other fun stuff.
Old 02-19-2008, 05:29 PM
chuck z's Avatar
Wow! You're lucky you didn't get hurt.
Chuck Z
1990 928 GT - Blk w/silk grey/black
1992 968 Cabriolet - Amethyst w/magenta/light gray
1989 944 S2 - Guards Red w/Black
928 OC Charter Member
Old 02-19-2008, 06:04 PM
RSKY BIZ's Avatar
Location: 'BETWEEN NORTH STAR BOROUGH...& THE CONCH REPUBLIC'
Is it any wonder ER's are a 24/7 operation?
Dang lucky, IMO!
Doc
"The real question is -- when you turn your car on, does it return the favor?"
AKODTV...Fall 08!
Weissgold/Brown '86.5 928S ~RSKY BIZ
Black/Champagne '88 928S4 ~SHARKY
Old 02-19-2008, 06:41 PM
WOW. you guys are scaring me, it's amazing dangerous not knowing something can be! What do you mean by "hot wire"?
1989 S2
1988 S
1987 944 n/a (sold)
Old 02-19-2008, 07:30 PM
928's have Motronic fuel injection system that has a heated platinum wire in the air mass flow sensor right after the air filter in the intake pipes area. Squirting flammable liquids and air into the intake when the wire is glowing hot results in ignition of the intake mixture so that's why the charge blew up the box and nearly took your head off.
Old 02-19-2008, 07:39 PM
Network Native
Danglerb's Avatar
So I'm getting don't do this right?
A little starting fluid, applied while cranking, just to see if that kicks it over isn't a totally bad idea. Trying to clear the injectors for 5 minutes maybe not so good of an idea.
Old 02-19-2008, 08:05 PM
lizard928s's Avatar
actually the 85/86 engines do this from time to time, no harm, just put the boxes back on and your good to go.
BTW the hot wire in the MAF doesnt cause this, I have standalone with MAP sensor on my engine and it did it that way too.
Old 02-19-2008, 09:07 PM
Architecture & Porsche's
Ha, I blew my side plenums off the first time I hit 8psi on the turbo car, scared the crap out of me...going sideways at 60mph & then BOOM! (engine die). Ha..
Mark (glad you're safe). PS: was this car a 5-speed? Looking for a non-running 5-speed BW 32v car.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-20-2008, 05:45 AM
NO, it's an auto, which i'm not crazy about. thx for all the info, interesting stuff.
1989 S2
1988 S
1987 944 n/a (sold)
Old 02-20-2008, 06:21 PM
DanielDudley's Avatar
Bad plug wires can cause a backfire by leaking over to another sparkplug in a cylinder with the intake valve open.
Old 02-21-2008, 04:41 PM
mistertate's Avatar
you know contrary to popular myth you're only suppose to use a little squirt of that ether and you'll actually get better results then dumping half the can in there
dude
Old 02-22-2008, 08:29 AM
