Looking for SOHC ignition timing map
Hi 928 brothers,
I'm looking for an ignition timing map for my n/a 944, but I'm having very little luck. I figured, because my engine is basically half of a 928 the timing maps would be very similar. Any map will do, either stock or performance. This is actually for a megasquirt project I'm working on. If I'm successful, it should be fairly easy to port over to the 928. Here's the current project if you guys are interested: http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/365785-944-microsquirt-plug-play-project.html Justin |
I will post in your main thread.
| All times are GMT -8. The time now is 12:42 PM. |
