Side Marker Bulb Replacement
I have a 90 GT that needs a side marker bulb replaced. It seems to be the only bulb on the car that is not referenced in the owners manual. Its the right rear one and it appears that the only way to get at it is to remove the entire fixture from in side the wheel well? Or, does the lens pop off?
Thanks all! |
the lens does not pop off. The easiest way is to take the fender liner out.
Thanks!
Have you considered upgrading to LEDs? Those last a lot longer.
You could also replace the markers with clear ones, if you like. You can get those with black or white housings, depening on what goes better with the color of your 928. |
| All times are GMT -8. The time now is 12:33 AM. |
