Network Native
Danglerb's Avatar
Lightbulb Spring Cleaning, ground points and connnectors, goop and tools
Spring is upon us, and after taking a bunch of stuff off my parts car and seeing all the corrosion on connectors etc., I'm motivated to do something. Replacing parts is expensive, but I suspect many of us have connections that have corroded beyond repair. Unfortunately nothing has changed in the new part to make it last any longer, unless we do something to preserve them.
Goop and sealing, before that cleaning or replacing. Here are some products that look promising.
******** Goops seem to vary from simple moisture blocking to active chemical corrosion resistance. Effective temperature range also varies, so make sure areas that need it use a high temp product.
Kopr-Shield
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=1369&itemType=PRODUCT&iProductID=1369
OX GARD
Has zinc particles suspended to fight corrosion
http://www.k1ttt.net/technote/antiox.html
Dielectric grease
CorrosionX
Tweek
Vaseline
Heat shrink tubing
Cold shrink tape
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=1387&itemType=PRODUCT&iProductID=1387
Liquid tape.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=10792&itemType=PRODUCT&iProductID=10792
Rubber boots
Glass fiber pen
http://www.sjdiscounttools.com/kti70550.html
Emery cloth
Contact file
Contact cleaner, Caig and CRC usually make good stuff.
Old 03-20-2008, 08:45 AM
