-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Warm Up Regulator Replacement Alternative (http://forums.pelicanparts.com/porsche-928-technical-forum/399369-warm-up-regulator-replacement-alternative.html)
orange9mm 03-20-2008 12:20 PM
I installed a WUR alternative about 2 weeks ago and things are great so far. I thought I would share my results. Ihave posted this info to other forums so I apologize if you have already read this somewhere else.
Product URL:
http://www.unwiredtools.com/utcis.asp
I am in no way affiliated with this company.
The product offering supports 3 stages, each one costs a little more.
1. UTCIS-G Warm Up Cycle and Fixed Control Pressure
2. UTCIS-V Warm Up Cycle, Control Pressure Mapped to Manifold Pressure
3. UTCIS-PT Warm Up Cycle, Control Pressure Mapped to Manifold
Pressure over 1 Bar ( for turbos ), Control Pressure Mapped to RPM
Unless
you are having WUR problems or have modified your motor and need more
fuel I don't think it would be of much practical use.
Essentially it replaces the Bosch warm up regulator on CIS cars with
a programmable control pressure regulator. It mounts in the same
location as the WUR with the addition of a ECU that I mounted on the
left inner fender in front of the coil on my 928. I can program the control
pressures during warm up cycle ( from 0c to 40c ) and also the control
pressures after warm up with manifold pressure ( .4 to 1 bar ) via my
laptop. Right now I am using the factory control pressure specs from
the warm up regulator. But this product allows me to adjust for
better WOT ( probably need a wide band sensor to really mess with this
). If I lived in a place where the climate varied dramatically I
could adjust the warm cycle as needed. Monitoring the control
pressure and manifold pressure is as easy as plugging in the serial
cable into my laptop. This price is a little on the high side but
compared to a new WUR it is cheaper.
Before install
http://mhenderson.dyndns.org/PhotoLi...ee73e6a641.jpg
UTCIS Installed in WUR Location
http://mhenderson.dyndns.org/PhotoLi...48d2d36390.jpg
UTCIS ECU
http://mhenderson.dyndns.org/PhotoLi...fca967a38d.jpg
My 928, wifes mini van, and my f150
http://mhenderson.dyndns.org/PhotoLi...b540ae7b08.jpg
