Transmission gear lube question
hello all, as the weather finally clears here in Detroit Michigan, thoughts turn to driving my 1988S4, what i would like to do is change over to all synthetic motor oil and gear lube, and I look to my fellow 928 owners for help, please state your brand name preference and weight - thanks - happy motoring
Old 04-09-2008, 11:37 AM
Network Native
Danglerb's Avatar
Mobile 1 or Redline 75W90 are my choices.
Old 04-09-2008, 11:39 AM
AMS or Redline are my choices as they still contain the necessary zinc/ZPP additives required for proper lubrication. From what I've heard, Mobil 1 has reduce the quantity of these additives to a level that isn't acceptable for older cars.
Just my $.02 worth.
Old 04-09-2008, 01:14 PM
nosnow4pc's Avatar
I have a 5-speed and an auto. With the 5-speed I've been told that Redline trans/gear oil is best but you have to mix the fluid with an enhancer. That being to much work I just used Mobile 1 with no side effects.
I switched my motor oil from Mobile 1 to Redline and have noticed that the pressure stays higher at idle when hot. I also kept hearing about the reduced additive issue so I switched.
I'll probably use Mobile 1 for the auto trans when I flush it.
Engine: Redline 20W50
Differential: Mobile 1 75W90
5-speed w/limited slip: Mobile 1 75W90
Auto: Mobile 1
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 04-09-2008, 03:24 PM
Old 928 Guy
surfdog4's Avatar
my 944 wanted GL-4 so i am trying Royal Purple..it's been working well so i bought some more for the 928
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 04-09-2008, 04:43 PM
