-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   turn signal problem (http://forums.pelicanparts.com/porsche-928-technical-forum/406961-turn-signal-problem.html)
bjenkins 05-01-2008 07:40 AM
turn signal problem
I am at a loss to figure out this problem. If I turn on left or right turn signal or flashers, none of the signals flash or even light up and the signal indicator on the dash comes on solid. If I lock or unlock my car with my alarm remote, all signals flash. I have replaced the flasher relay and checked all applicable fuses. Any ideas?
surfdog4 05-01-2008 09:36 AM
you might try checking your emergency flasher switch on the console...the turn signal signal travels through the emergency flasher switch..
I figured this out when i pulled all the switches as part of the console rebuild and noticed the turn signals did not work but the indicator in the cluster was on solid..looked at the schematic and saw it routes through that switch
bjenkins 05-03-2008 05:53 AM
Good call. If I twist the emergency flasher button, the turn signals will work. Time to R&R.
surfdog4 05-04-2008 05:58 PM
These forums are great, aren't they? Stuff like that can be a real head-banger and then you find somebody that has just the right answer!
I know it has bailed me out a few times..on this and other cars
