Need a 86.5 flywheel for 5spd wtt
1986.5 928 auto swapping in an 81 5spd box, tt, and dual clutch. And oh yea the master cyl firewall. Anyone have a 5spd flywheel for a 86.5 with 100 teeth for ignition ring?
Preciate it. PM
Willing to trade for parts. Or if price is right. Thanks
Mark in CT.
203 450 8149 or text.
Old 12-06-2020, 02:21 PM
honerboys's Avatar
do you have a part number? - i have a couple of flywheels here (i think) - been a while since i've gone through this stuff
84 928 S - SOLD
2012 Cayenne S
Old 12-07-2020, 08:40 AM
Thanks for looking
928 102 078 01
Should have a 100 tooth ring.
Best Regards,
Mark
Old 12-08-2020, 04:54 PM
honerboys's Avatar
hey javaschlava - i looked and i'm a little confused - on the double disk cars the starter teeth are on the intermediate plate - the actual flywheel that's attached to the crankshaft doesn't have teeth - so i have an intermediate plate that says 1986 on it (don't know if early or late) - but it has 162 teeth on it - i don't see a porsche part number on it but the sachs number is ...3059008233 - of course i don't know what the changes were between early and late so they could have changed the whole setup
84 928 S - SOLD
2012 Cayenne S
Old 12-09-2020, 05:11 PM
I may be confused, I have a 32 valve 1986.5 engine. I thought I need a flywheel with an ignition ring to fire the crank position sensor. Maybe your 86 one is for the 4.7 16 valve. The 87 32 valve engine flywheel has an ignition ring but 60 teeth from what I read. 86.5 is a unicorn and has 100 teeth. Hope that’s what is true. Ya never know these days.
Thanks for any help possible.
Mark
Mark
Old 12-09-2020, 06:02 PM
BTW
I’m sorry to make you count all the starter ring teeth.
Thanks,, now I know how many there are!
Best regards,
Mark
Old 12-09-2020, 06:04 PM
Still looking for a used 5spd flywheel for 86.5 32 valve motor. Anyone, any condition, any where. Thanks Mark
203 450 8149 in CT
Old 12-26-2020, 03:18 PM
928 intl has one Used Flywheel 85-86 5sp-928intl.com
Old 01-12-2021, 04:27 PM
Made one.
Thanks for looking. I was able to remove the ignition ring from the 86.5 flex plate and index it onto the 81 5spd dual flywheel. With the help from Machine shop Bill Carlquist. Shim it just enough to make it snug and then tack weld it up. Wa la it starts and runs.
Finished it off by welding it in more equidistant places so she will stay on there. Thanks to a previous post for the idea.
Old 02-09-2021, 02:57 PM
