erwalker's Avatar
S4 rims on an '82
Does anyone know if S4 rims (16 x 7 front and 16 x 8 rear) will fit without modification on a 1982 model? Will I need spacersat all? Or is there a site somewhere that lists which rims will fit which cars? Thanks in advance, Ernie
Old 06-25-2008, 09:04 AM
Ernie, the guide that I used when I put cup rims on my 79 was:
http://www.928registry.org/928-wheels.htm
Just look on the rim by the valve stem. That number is the wheel offset in millimeters. The new wheels that I got were 55 mmm offsets front and rear which worked fine. You may need to add a spacer to the rear though to get the clearance needed for the brakes....
Curt
Old 06-25-2008, 09:28 AM
Heavy Metal Relocator
rhjames's Avatar
Ernie--
S4 (commonly called flats or flat disc) will work on all 928, no spacers needed---(although I don't know why one would put set on anything newer than and S4)---
using newer wheels on older cars is not a problem. you get into trouble when trying to use older wheels (15 inch phone dials, for example) on newer cars. the brake calipers on the later cars are of a larger diameter, requiring the use of larger diameter wheels.
if you are considering putting other Porsche wheels on your 928, I regularly suggest that you visit Wheel Dynamics' website. they have a wide selection of both OEM Porsche wheels and aftermarket, on various Porsche models, with a basic listing of what fits and what doesn't.
Andrew Olson over on Rennlist also has a wheel fitment guide.
good luck--
--Russ
Old 06-25-2008, 09:59 AM
erwalker's Avatar
Thanks for all your input - got the rims on and they look awesome! No problems with fitting or clearances. Looks even better from behind even though the rims are only 1" wider. Thanks all! Ernie.
Old 07-01-2008, 12:19 PM
