Need to replace driver's door lock on my '79.
Hello, 928 is in the shop with door apart, and mechanic said the door lock cylinder input arm is broken. I guess I need the driver's door lock cylinder assembly? I had put the key in a while ago, turned it (there was resistance) and "pop". A used one would be fine, just hoping to find one ASAP for the Seattle area? Thank you!
any of the major 928 parts suppliers should be able to help with this-----
928 Int'l 928 Specialists 928sRus to name a few...... not sure if Pelican Parts has this as I did not see one listed. --Russ |
there is a good chance that 928 International will have used ones...
| All times are GMT -8. The time now is 04:01 AM. |
