Need to replace driver's door lock on my '79.
Hello, 928 is in the shop with door apart, and mechanic said the door lock cylinder input arm is broken. I guess I need the driver's door lock cylinder assembly? I had put the key in a while ago, turned it (there was resistance) and "pop". A used one would be fine, just hoping to find one ASAP for the Seattle area? Thank you!
Heavy Metal Relocator
any of the major 928 parts suppliers should be able to help with this-----
928 Int'l 928 Specialists 928sRus to name a few...... not sure if Pelican Parts has this as I did not see one listed. --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Old 928 Guy
there is a good chance that 928 International will have used ones...
1990 C2 Cabriolet Guards Red ![]() '81 928 Zinnmetallic Project Car (sold) )'87 944na Maraschino Red Metallic (sold) )
