Question 85 ignition help. need diagram or configuration help
behind the key where the ignition harness or plug is, i accidentally unplugged it and the tumbler of sorts came out. i was able to put it back together and now it will turn over but not crank. the tumbler inside is obviously not in there correctly.
does anyone have a diagram? or link?
Old 08-15-2008, 10:53 AM
Banned
Normy's Avatar
I bet if you called 928 International and told them what was going on, they could probably tell you over the phone, while you have the parts in your hands, how to put the thing back together. Try them at 714.632.9288.
Good luck-
N
Old 08-15-2008, 11:12 AM
thx. ill call now.
how did you get your signature at the bottom of your post? with your car info etc?
Old 08-15-2008, 11:19 AM
called 928 int. wasn't aware of any diagrams to be found. just said it would only go one one of two ways possible.
just bought a new switch. settled.
Old 08-15-2008, 11:46 AM
