928 paint question (clear coat?)s
Can someone tell me definitively whether a 928S2 (1986.5) black paint has a clear coat or is it all color? I have a very slight acid rain issue and want to sand through it if all color.
Old 09-06-2008, 04:58 PM
It should be solid color one way to find out is take some 2000 get wet&dry sand paper and wet it and sand a small spot on the car if it sands black on the sand paper then it is all color if it sands white then it has clear coat on it. I hope that helps.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 09-06-2008, 05:10 PM
After a while away, thanks I will try that on a spot low and away.
Old 09-14-2008, 05:19 PM
