leak?
It has been raining quiet abit and i normally have a cover on the car, but i have noticed water on the inside of the car. had a look and all the passenger side was soaking. looks like the leak is coming from above the central electrics. there is something that looks like a black vent there which is leaking. i pushed on the vent and a pile of water came out, seems like theres a well up there. what is this vent? the water must be getting somewhere has anyone else had this problem?need to stop this fast!
Old 10-19-2008, 10:16 AM
You need to clean out under the hood where the bower for the heater is it must be full of stuff. And is this car have a sun roof?
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 10-19-2008, 11:02 AM
yes the car has a sunroof which leaks a small bit sometimes, iv cleaned the drains . is there a drain by that blower also?can you open that blower unit without damaging it?theres not much room to work with and dont want to take the hood off.
Old 10-19-2008, 01:10 PM
Network Native
Danglerb's Avatar
The blower is behind a metal barrier on each side, one between it and engine, and one between it and the inside of the car. The motor barrier has a flap for water to drain out into the engine compartment. If leaves or other debris gets into the blower area the drain gets blocked and eventually water drains into the cabin.
Take off the plastic cowl panel cover, over the wiper and blower motors in front of the windshield and clean the area out.
Get the electric panel dry as soon as possible. You may need to clean all the connections if they have started to corrode.
Old 10-19-2008, 02:05 PM
ya iv to get in there again and clean all contacts! is this drain visible under the car in the engine bay? if so i could blow air to clear it.
Old 10-19-2008, 02:13 PM
Network Native
Danglerb's Avatar
I'm not sure if you can see if from below, but you might be able to see it with the air filter box out. I'll look for a picture to post.
Old 10-19-2008, 02:16 PM
Network Native
Danglerb's Avatar
Take a look at the black flap about a foot down and foot from the left side of the bay.
Old 10-19-2008, 02:21 PM
ok perfect.cheers danglerb
Old 10-19-2008, 02:43 PM
Xlot's Avatar
You've probably noticed or realised, but for the benefit of others with RHD cars, its worth noting that on your car, the flap will be on the other side than shown in danglerb's picture.
The HVAC system and electric system are mirror images going from LHD to RHD cars.
edit: Oh - you can poke the flap from beneath the car if you put it on a lift or on stands.. but careful of the face full o' dirty water
Various manual S4's
Old 10-19-2008, 06:40 PM
yes my car is a rhd. took abit of looking but found it when I removed the air intake. it was blocked with leaves and a large cable was keeping the flap shut. you wouldnt believe the amound of water there and also the amount that got into the car! its going to alot of time to dry out and clean the electrics. so thanks for the replies and cheers danglerb for the pics ment I knew what I was looking for and saved time poking around.
Old 10-20-2008, 02:38 PM
