-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Engine stand part really worth $$$ ?? (http://forums.pelicanparts.com/porsche-928-technical-forum/435113-engine-stand-part-really-worth.html)
N2O-SHARK 10-11-2008 09:42 PM
Is this engine stand adaptor for the 928 really worth what these guys are bidding so far?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEWAX%3AI T&viewitem=&item=230299157737
My universal engine stand from Harbor Freight fits the 928 engine just fine and was under $50. I guess if you have a Porsche repair shop it's nice to have the "perfect" fit.
Danglerb 10-11-2008 11:45 PM
People with 928's often do stuff that doesn't make sense.
I've seen them in shops not being used while the HF style are, so go figure.
MPDano 10-12-2008 06:20 AM
Yikes, thats going for a lot of $$. I also used a universal stand and it worked perfect. I guess if your going to put your spare engine with spotlights toward it, then it would be cool :D
redrider044 10-12-2008 07:03 AM
My father always told me, for every chair, there is an a-s
jmorton 10-12-2008 08:58 AM
Well I guess I am one of the asses that fits the chair...
I have been bidding on this but it is getting rather high. I had the luck of using one of these yokes on my good engine stand and it was far more comfortable to work pieces than when the block was mounted using the "standard" adjustable mount.
The factory yoke mates to the bell housing flanges spreading the load. This is really nice when torquing / untorquing heads, timing cams, etc.
Hopefully the bidding on this yoke will not get too crazy. The person that owns the one I borrowed paid less than $200 for the yoke, a lift bar and under engine to stand brace.
$0.02
MPDano 10-12-2008 10:03 AM
Good to know that there is a reason for the bidding madness. Good luck on your bidding, I hope you get it!
N2O-SHARK 10-12-2008 02:47 PM
$0.02
Makes sense. I made a front support out of 2.5" exhaust pipe clamped to the front of the engine stand. Small block of wood between the oil pan and pipe.
First time I tried to torque a head bolt down told me with out the front support I'd be in trouble.
Still surprised by the price.
redrider044 10-12-2008 05:50 PM
Sorry if I offended you. I didn't think this yoke made that much of a difference.
5l32v4c 01-13-2013 11:27 AM
Just about to transfer my 32v engine from the hoist to a standard engine stand, without the Porsche yoke. This is one heavy beast and I'm really nervous about all that weight hanging on just the bell-housing flanges.
I know that you're supposed to support the engine from underneath while torquing bolts etc. but even having the engine sitting still on the stand for cleaning / disassembly etc. makes me nervous.
Guys, make me feel better.
Pete R 01-13-2013 11:33 AM
My standard stand adjusted fine to fit my motor. A simple 2 x 4 between the stand and front of the motor on the pan stabilized it and took care of any load issues
Danglerb 01-13-2013 05:01 PM
Here you go, now you can worry about something else.
Head stud torque question.... - Rennlist Discussion Forums
Just don't use the stand with the T base, only the H or A. I don't recall seeing anybody prop up the front before torquing the heads, but could be I wasn't paying enough attention.
