-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Best procedure to remove S4 MAF? (http://forums.pelicanparts.com/porsche-928-technical-forum/437859-best-procedure-remove-s4-maf.html)
artikulieren 10-27-2008 12:16 PM
I'm hoping to find out what the best way is to remove the MAF sensor on my '87 S4?
Thanks!
stratfordshark 10-27-2008 12:42 PM
It's very simple. The MAF is held on to the rubber throat on the throttle body by a single jubilee clip.
To access MAF first remove air filter box by taking off intake tubes then undoing the 4 10mm nuts and the jubilee clip securing hose to air divertor valve.
You can loosen the clip either with a long screwdriver aimed through the intake 'legs', or using a 7mm wrench. If you use a wrench it's advisable to tie a long piece of string to it and tie round wrist as you could drop it into vee of the intake!
Once clip is loosened by a turn or so you can pull out the MAF. It's still attached by the 6-way plug going to LH ECU so remove this and the MAF is free.
artikulieren 10-27-2008 02:31 PM
excellent, thanks for the advice! It looked as though the clip was the only thing holding it in place but I didn't want to gamble and get myself into a 'situation'.
blitz928 10-27-2008 06:22 PM
Once air box is removed, Remove Passenger side fuel rail cover. You'll need a foot long Common (flat) screwdriver. You can unscrew the clamp. Only Unscrew enough to loosen the MAF. If you loosen it too much the clamp will slip and you'll have a difficult time reinstalling. Because you'll have to reach in too hold it to tighten again.
John Speake 10-30-2008 09:52 AM
Even when you have lossened the clip (only needs a couple of turns) you may find the MAf won't release from the rubber elbow. This is because with the heat in there it can stick to the rubber. A wiggle and a twist can release it.
Herr-Kuhn 10-30-2008 06:35 PM
You may have to lean over the engine to get to the bottom boot clamp...it's a bit of a bugger. If the boot is dry and brittle it should be replaced...they are only about $50.00.
