Network Native
Fuel tank support padding?
I don't care for the factory foam stuff used on the steel support frame for the fuel tank, and I've been looking around for something better for months.
First attempt was some 1/8" thick closed cell foam shelf liner. Excellent stuff, looks very durable, but was a bear to cut to fit the supports and glue it on, and proved a bit tight (too thick or not squishy enough) when the tank was bolted up. Next I found some carpet runner, thin vinyl type sheeting, that appears to have excellent abrasion resistance, but how to stick the stuff on reliably? So I am wandering the aisles looking at two sided tapes, and all of a sudden I see the perfect item, or so I am thinking so far without trying it, Gorilla tape. This stuff is "like" duct tape, but not a gooey adhesive, and its STRONG. I plan to use it directly on the support frame after painting, a single layer stuck to the frame between it and the fuel tank with the edges rolled over and stuck to the metal frame. More after I give it a try. |
Hey Danglerb,
Please don't forget to keep us posted on how this works out as I may want to use this stuff when replacing the fuel tanks on one of my other cars. |
