Arrgh Matey!
Who has the cheapest cages for the 928?
Mason '90 Gt Black/Black 90k |
Freiherr
Based on the intended use of a roll cage, I wouldn't be looking for the cheapest. I'd suggest building it in the chassis.
Abby Normal |
Network Native
Summit has kits that might make a good base to build something specific for a 928.
http://store.summitracing.com/egnsearch.asp?N=700+115+4294865395 This one says its for a 928, but it also says bolt in and I think welded is the only way to go. http://www.festivegarage.com/roll-race-porsche-p-5618.html This thread has some nice picts of JohnV's cage. Custom 928 Roll Cage More links http://www.racefabinc.com/rollcages.htm http://www.speedwaremotorsports.com/PROJECT_GALLERY/c3/p218/Porsche_928/pages.html |
Heavy Metal Relocator
long before you start any welding, be sure to research the type of tubing (wall size, tube diameter, and material) that is required for what use you are putting the car in.
NHRA, IHRA, PCA, and other sanctioning bodies are very specific as to what's required. certification of cages is also a requirement for some sanctioning bodies from year to year. (and these requirements change somewhat often) -Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Arrgh Matey!
I know it... I just wanted to see if anyone had plans drawn up already so I could mortise up and go to work instead of measuring all day long and cutting, and measuring and cutting KNOW WHAT I MEAN.
Freiherr
Here's mine;
Abby Normal |
