-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   auto gearbox problem (http://forums.pelicanparts.com/porsche-928-technical-forum/443823-auto-gearbox-problem.html)
86porsche 11-30-2008 06:59 AM
I have read some other threads but cant find the same problem. sometimes my car wont shift to 4th gear but sometimes it does if I blip the pedal.
lately this is not working and it just stays in 3rd. I need to do an oil change and this might solve it but maybe its something else. has anyone else had this issue? I read it could be a vacuum leak or the cable is stretched but dont know where to look. can any point out where to find these?
Danglerb 11-30-2008 09:07 AM
First thing I would try is drain and refill tranny fluid making very sure its the correct amount.
MPDano 11-30-2008 01:06 PM
Yup, do the trans kit. I am the one with the Bowden Cable issue and was able to adjust the slack out. The other thread with the 3 speed on his 4 speed was evozine. He still hasn't resolved his issue, but I think he will be pulling his trans to fix his. He never got his in 4th, you have. I would take Danglers advice and do the filter and fill up with fresh fluid. This will probably fix your issue.
86porsche 11-30-2008 01:54 PM
ok thanks for the reply lads. hopefully some new fluid should do the trick then.cheers
