No Band
Need Electrical information...
Would look this up myself, but my cpu disk drive is toast... I found the problem with my wiring harness, and the wires are burnt in two.. I removed the harness while trying to make sense of the colors on the insulation but to no avail. Can someone please give me an idea of what pins in the multipin connector located on the passenger side fire wall go to? I know which ones go to the starter, the only ones I need are the ones that go to the alternator, oil pan, and I believe there is an oil pressure switch? located next to the alternator under the car...
Any help would be much appreciated..
He was a helluva plumber and his costume was self explanatory |
No Band
Bump-Anyone??
Network Native
I checked my wiring diagrams for an 83, and they don't break out the 14 pin on just one page, its spread over all the different functions. 928 motorsports sells a replacement harness, maybe they have a pin out?
If nobody else answers I will look more tonight. |
No Band
Thanks Danglerb.. I will see if they might have a pin diagram showing where they go to.... I could probably figure it out as I only need the low oil switch, the oil pressure switch and the alternator (Small wire).... Its just that they all look like the same color on my harness.. lol
Network Native
The 83 diagrams are those current ladder things that relate nothing to location, and the harness changes between 83 and 84, but .... This is what I "thinK" is going on
Pin 1 Blue exciter for alternator. 2 Blue / Black Oil pressure (Wk) 3 Blue / Yellow Coolant temp (G) 4 Blue / White Oil pressure (G) 5 Blue / Green Coolant temp (W) 6 Green / Blue Oil level switch 7 Red / White supplementary air valve. 9 Black AC compressor clutch 10 Black / Yellow cranking ignition power. 14 Yellow starter solenoid
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. Last edited by Danglerb; 12-05-2008 at 07:10 PM.. |
