Thumbs up Twin turbo dyno nexted week
I am going to put the twin turbo back on the dyno it is set for nexted week I am thinking 480 to 490 at the wheel with more boost . I was at 445 rwhp at 8 psi so i think 12 to 13 psi this time mit get me there or more maybe. Time will tell. Ill post dyno sheet nexted week.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 12-16-2008, 03:20 PM
I have my old race car coming back nexted year, We are pulling the motor out and putting in thefull race motor in and we are taking it up to the track so that i can run it and get it all tuned in the right way for nexted season.
Old 12-16-2008, 03:23 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
If you're at 445RWHP @ 8psi, going with 50% more boost at 12psi will net you a good bit more than 490RWHP...
Make sure you post up a video, can't wait. I wish I could go twin turbo..
'81 Euro 'S' 928 5-Speed 5.0L Hybrid "Ricerschnitzzzle" Wish list: RollBar, New Helmet and driving lessons
Wishes Done: Body kit, seats, No cat, Headers, X, Afterburners, 3" exhaust, short shifter , 17" TT Rims, 250HP N2O, MSD ignition w/retard+rev limit, MSD billet distributor, Accel Coil. 5.0L block, ported heads, JE race springs + .503 "S+" cams
Old 12-16-2008, 03:37 PM
This are the old callaway turbos wich are the IHIs that do not flow like the gt twin BB.
Old 12-16-2008, 03:50 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
Agreed but psi is relative to flow. ie.. it takes a certain amount of flow (mass) to create the measured manifold pressure. Doesn't matter which two turbos you pick, but if both are generating 12psi on the SAME engine, they are both flowing the SAME at that point.
Twin K27's might spool a tad slower than the GR BB turbo's but will still hit the same peak HP rates, given the same manifold PSI. The torque curve will not be as flat as your tubo's will build manuifold pressure at a slower rate due to spool time, however once at 12psi they will generate the same power as any other turbo at 12psi.
The big difference is twin GT BB turbos could generate 30psi and get htere at a lower rpm, where your turbos might peak out at 15 or 20psi.
Old 12-16-2008, 03:58 PM
Mine were never matched up when callaway did these cars so in the map on this turbos they will bo off the map at 12 psi . But we will see . This car is getting the GT twin BB on it .
Old 12-16-2008, 04:06 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
It will be sick with twin GT BBs..
Even upgrading to a pair of K27's can be done cheaply. About $500 a pair on ebay.
Old 12-16-2008, 04:09 PM
Well it is sick now with the callaway stuff. When we put the twin GT BB on it we will get 500 rwhp with it with little boost . It will be very sick then.
Old 12-16-2008, 04:20 PM
Network Native
Danglerb's Avatar
Pair of K27 for sale in the 944 classifieds here.
12 psi in the manifold isn't always 12 psi in the cylinder. At some flow level the choke points start to drop serious psi.
Dyno numbers should be great with this cold weather.
Is this boosted car the one going on the track?
Old 12-16-2008, 04:36 PM
No it is not going on the track. This is the old callaway twin turbo 16V 4.7l euro motor
Old 12-16-2008, 05:28 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
Did you buy the CAlloway listed in Pensacola a couple months back?
Old 12-16-2008, 05:38 PM
No from Wisconsin. The one in Pensacola the guy is smoking something if he thinks he is going to get $15,000 for that car it is a mess
Old 12-16-2008, 05:43 PM
lizard928s's Avatar
yes next time you might see those numbers with that PSI.
Old 12-16-2008, 09:49 PM
Fabio421's Avatar
Mark, PM me your new phone #'s. I tried calling you last weekend and I couldn't get through.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 12-17-2008, 05:15 AM
Update
I am on the dyno on 12/23/08 Ill post sheet when done.
Old 12-19-2008, 04:35 PM
Fabio421's Avatar
On a Tuesday?
Old 12-19-2008, 07:20 PM
Originally Posted by Fabio421 View Post
On a Tuesday?
Yes
Old 12-20-2008, 12:59 AM
Update
I had to cancel the dyno run this tuesday made it for next tuesday. I had to go to fort meyers florida for work.
Old 12-24-2008, 08:22 AM
2Quick4u928's Avatar
Thanks for the update, was watching & wondering also....Happy Holidays!
Old 12-25-2008, 12:31 PM
Here are some pics before paint. I am still blocking on the car as well.
Old 12-26-2008, 02:07 PM
