-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Heater A/C control knobs (http://forums.pelicanparts.com/porsche-928-technical-forum/450014-heater-c-control-knobs.html)
redrider044 01-06-2009 12:26 PM
I have a '78 928 that is missing a heater A/C control knob. I ordered one from Pelican along with the retaining clip that is supposed to fit all 928's thru '86 but it doesn't fit my '78. The stem/shaft part that should fit thru the control panel is too thick. I called Pelican & they said the knob for a '78 is N/A. I returned the part & ordered one directly from a local Porsche dealer & it was the same part. What do I do to get this part to fit? Do I file down the replacement knob or get a later model control panel or ???? Once again, many thanks for a great forum.
Danglerb 01-06-2009 01:55 PM
Pictures needed.
Are you restoring to original or just trying to make it work?
redrider044 01-06-2009 02:37 PM
Just trying to make it work.
MPDano 01-06-2009 03:40 PM
Sounds like if you can modify it to make it work without it looking bad, then I would say modify it. They already said it's NLA. Your only hope is if someone just happens to have a used spare somewhere.
