head shaving
Can anyone tell me wht would be the limit for shaving head and block so as not to avoid problems with pistons or pressure,This is alumina 928 model 1979 4,5liter
Old 01-22-2009, 12:34 AM
928s's Avatar
Is the purpose just to clean up the surface? Only a small shave should be required so no worries about the thickness, if you shave too much the water bridge can become an issue.
Old 01-22-2009, 02:11 AM
The WSM has an area showing the limits and how to measure to determine if the head has been previously machined. IIRC the total machining cannot exceed 2.4mm and requires the installation of the thicker head gaskets or the engine will be subject to valve damage if the timing belt should break.
Dennis
Old 01-23-2009, 07:28 AM
power gain
I have to remove 0.5 mm of coroded top on each side, Head and block so 1mm will be Ok, Will i get anymore power while do this?
Old 01-23-2009, 02:58 PM
Network Native
Danglerb's Avatar
Do the pistons have that much clearance to the flat spots of the heads?
Nothing powerwise that you would notice, but combustion might require a higher grade of fuel, hard to say messing with the squish area.
Old 01-23-2009, 05:02 PM
Just checked the WSM and page 15-19 indicates a .4mm limit so I stand corrected. i.e. the L shaped blocks on each side of the front and back of the heads should not be any thinner than 23.6 mm after machining. If less the 1.4 mm thick head gasket must be used.
Dennis
Dennis
Old 01-23-2009, 05:21 PM
Hey! Nice Rack! "Celette"
rich's Avatar
Dennis
My blocks are less than 23.mm as a result I had piston, valve, block and cylinder damage as a result of a broken cam. I used Cometic gaskets to pick up the clearance.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 01-23-2009, 10:30 PM
