928 Bro's Avatar
Tire size
What is the widest size tire that can be put in the front with the standard 16'' slotted that wouldn't hit the inner put of the chassis?
Old 02-05-2009, 12:36 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
a 225 series. You might be able to squeeze a 235 on a 6" rim but for safety I would not recommend it. With a stock 6" rim, you're no where near rubbing on the inside with any tire that's safe to put on.
'81 Euro 'S' 928 5-Speed 5.0L Hybrid "Ricerschnitzzzle" Wish list: RollBar, New Helmet and driving lessons
Wishes Done: Body kit, seats, No cat, Headers, X, Afterburners, 3" exhaust, short shifter , 17" TT Rims, 250HP N2O, MSD ignition w/retard+rev limit, MSD billet distributor, Accel Coil. 5.0L block, ported heads, JE race springs + .503 "S+" cams
Old 02-05-2009, 01:44 PM
Network Native
Danglerb's Avatar
Not much point in anything wider than 225 on the factory slots which are I think 7", some have used the wider S4 8" rear with 245 "or so" width. Once the tread exceeds the rim width traction and handling benefits drop fast.
If you just want to "fill the wheel well" maybe look into spacers?
Old 02-05-2009, 01:45 PM
928 Bro's Avatar
I most have the s4 8'' you are talking about because it has 245 /45 /16'' ,so they normally go on the rear? How wide can I go on the rear with them ?265, 275 - I don't want crazy but with the nice rear of the 928 you want some nice wide tire there too.
Old 02-05-2009, 02:56 PM
The 16 inch slotted S wheel is a 7 inch. The S-4 used an 8 inch on the rear only. Many people have put 245 tires on a 7 inch rim then the sidewall is pinched in at the rim. As Mike commented the car will handle worse , corner at slower speeds with too wide a tire.
Old 02-05-2009, 04:06 PM
928 Bro's Avatar
So go with the 245 on the rear with the 8'' rim and 225 with the 7''. This should be a good combo right?
Old 02-05-2009, 07:15 PM
Heavy Metal Relocator
rhjames's Avatar
yes-
you could also locate another pair of 8 inchers and use them with 245's on the front as well.
then you would be squared----
adding spacers to the rear would also help.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 02-05-2009, 08:12 PM
928 Bro's Avatar
Old 02-06-2009, 08:53 AM
RicerSchnitzzzle
N2O-SHARK's Avatar
For a little over 500 bones you can get a set of 4 aftermarket 18" rims 8/10" wide. You could then go 295 rear and 255 front.
Or if you can find a set of used 996 wheels, the offset works well. 17x 7.5/9". You can go 275 reaar and 245 front. Just make sure they are not the Boxter rims as offset is wrong. Lighter than the knock off wheels and look good on the shark.
Old 02-06-2009, 10:01 AM
928 Bro's Avatar
I'll keep it in mine in my search. Thanks Guys
Old 02-06-2009, 11:49 AM
