Clearing out the Garage... Cheap Goodies!
Just threw some stuff on ebay..
All parts came off running engine. If not happy, email me and return items for refund. BIN prices: Pair of 32v heads 85-86 $150 each (No cams) Pair 85-86 exhaust manifolds (great upgrade for 78-84) $100 Pair of oil pans $50 each Timing Belt Tensioner with Tension Roller Assembly $75 4.5L Rod set $75 4.5L/4.7L Crankshaft $100 Complete set Euro Fog Lights- Housings, reflectors, lens, no bulbs. Very clear lenses. $60 Square Tooth Cam Gears- Decent, coating not worn through $50 (78-82) $20 more for brand new square tooth Timing Belt! Euro non-S Throttle Body. Very good shape. $75 '81 Smog Pump and lines $50 '81 A/C compressor $50 16v Air regulator $20 Have some other goodies not listed yet.. OB front engine belly pan, 85-86 Airbox assembly (No filter), Stock 16v plug wires (Decent), 2 16V coils, Accel Super Coil (Yellow), Couple complete 16V timing belt cover sets, Stock cross brace, needs refinishing but is not bowed, 16v Distro, Original Spare (Inflated to test), CIS fuel lines, Water X-over w/thermostat, 16v Oil Fill/Seperator. I also have another set of 32v heads that will be available next week. They are off an engine I can not gaurantee was running so I need to scope them out first. Busy week at work but I can ship out starting early next week. |
Cam Covers and Airbox gone.
Euro Fog lights and Exhaust Manifolds gone. Thanks Russ! Plug wire set and Belly Pan gone. |
Auctions end today. Several have no bids.. get it cheap.
Look at you you been holding out on us. Nice!!!!!!!!!!
| All times are GMT -8. The time now is 09:54 PM. |
