Network Native
Danglerb's Avatar
80 alum ball joint -> steel, whats needed?
With a 1980 928 that has aluminum ball joints, what needs to be changed to put in the new steel ball joints?
Old 04-09-2009, 01:43 PM
s928s's Avatar
the only difference is the 2 ecentrics on the bottom. The shock support mount is the same.
the early have 2 different size ecentrics I believe 21mm and 18mm. The later have 2 of the same size. When you have them off you will see 1 weith a larger diameter, you need 2 more of them.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 04-09-2009, 01:53 PM
nosnow4pc's Avatar
just the ecentrics. The old mount will have longer threads, if that bothers you buy a used set cheap or take a hack saw and remove the extra thread. When I did this on my '82 I just replaced the ecentrics left the extra.
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 04-09-2009, 02:50 PM
tedward515's Avatar
When did they switch to the steal ball joints?
89 928 S4 5spd project
81 928 5 spd gone
84 928S 5 spd euro gone
71 911T gone
83 944 gone
Old 04-09-2009, 05:23 PM
Heavy Metal Relocator
rhjames's Avatar
the change over was with the "S" models if I remember correctly.
if you really want to take a step up, you could change out the whole front suspension/brakes for an S4 setup. add S4 calipers and rotors to the back and you're done.....
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 04-10-2009, 08:53 PM
