2Quick4u928's Avatar
Tensioner Roller bolt torque value or...
Asked this question under "Another timing belt question but no replies, so will try a seperate post here...
This is regarding the 10mm bolt after new tensioner roller installation (Step 13 TB Svs. Rennlist)...I cannot locate a torque spec for this bolt. Directions here state "Turn tensioner screwbolt counter-clockwise to full loose." Just does not make sense to me as the nut could vibrate off then later roller decides to bounce around like a pin-ball machine inside the TB covers. Inputs? About to check the svs manual right now....thanks
Pat
So. of the Rio Grande
Long distance relationship w/my 88' S4 5-Speed Bi-Turbo Widebody In Work; Italy
Old 03-13-2009, 05:35 PM
