-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   ID Auto Tranny Part? Vacuum Part? (http://forums.pelicanparts.com/porsche-928-technical-forum/463981-id-auto-tranny-part-vacuum-part.html)
MPDano 03-19-2009 07:14 PM
I can't seem to find the part that connects to the vacuum line at the tranny. Vacuum Modulator?
psychII 03-19-2009 07:52 PM
if you have the PET diagram, look at illustration 308-55. I think its the pressure control valve #26, Depending on your tranny, either 126 270 257 9, or 126 270 937 9.
Of course, double check to make sure I am correct...
Danglerb 03-19-2009 08:14 PM
Here is a diagram c/o DC auto.
http://forums.pelicanparts.com/uploa...1237518792.jpg
MPDano 03-19-2009 08:33 PM
I am looking at PET and don't see a 308-55, mine only goes to 308-10 then 309. I have a 1981 3 speed. Am I using PET incorrectly?
Danglerb 03-19-2009 10:48 PM
Hmmm, my diagram was from a 4 spd apparently.
928 (1983-1986) (A28.01/04)
but what about a
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=OEM-1232700079&catalog_description=Genuine%20Porsche%2 0Part%3A%20TRANS.DIAPHRAGM
ice-hot 03-20-2009 04:47 PM
MPDano- here is a scan from a "82" MY service manual. I have more info on shift point adjustments if you are interested. Hope this helps.
Johnhttp://forums.pelicanparts.com/uploa...1237592813.jpg
ice-hot 03-20-2009 04:48 PM
Sorry about the first post, wrong pic!
MPDano 03-20-2009 08:14 PM
icy-hot, that's it. Do you know where this is in PET or a part number?
Danglerb 03-21-2009 12:39 AM
Another diagram.
18
1002703307
Hydraulic control unit for control pressure with regulating valve
A22.01/02
$186.80
(18)
7222701007X
Regulating valve
82
A22.04
$175.06
http://dcauto.gotdns.com/illustration/index/61730806
http://forums.pelicanparts.com/uploa...1237620449.jpg
MPDano 03-21-2009 11:35 PM
I actually plugged the vacuum line that goes to this modulator and I like the shifting better. Before it was very mushy, it shifts better now. Is this bad to not use this vacuum modulator? Also, I can still hear some sort of vacuum when I accelerate, so this is not the source.
