-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   ??Is There Supposed To Be Another Coil?? (http://forums.pelicanparts.com/porsche-928-technical-forum/468140-there-supposed-another-coil.html)
EIPtuningR32 04-09-2009 10:53 PM
i about 8 or 9 months ago bought new ignition wires for my (i think its an 82 but i have no idea cause the carpet on the interior says 81) 1982 928S euro. i have installed all of them in the correct places but one wire. its a very long wire that has the same connector on it as the wire that goes from the ignition coil to the distributor. i have looked all over and havent found any place to hook the wire to on neither the distributor or the "missing" coil....if i have one. any ideas on where this wire is supposed to go. i bought the wires from Kingsborne if that helps at all. thanks. - Charles
Danglerb 04-10-2009 12:06 AM
84+ Euro S has dual coils, but basically the same wiring otherwise. My guess is that they just make a single kit for several models.
EIPtuningR32 04-12-2009 12:47 PM
great man.... thanks for the info. ill just cut the wire off.:D
