-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Need help identifying hoses!!!!! (http://forums.pelicanparts.com/porsche-928-technical-forum/472223-need-help-identifying-hoses.html)
EIPtuningR32 05-02-2009 09:37 AM
i have quite a few hoses that lead to nowhere:confused::mad:. some of them have unique bends in them so that might help out with this process. if any of you know where or what these hoses go to, that would be awesome. here are the pics:
the one that goes down the intake runner and turns a hard left
http://i573.photobucket.com/albums/s...2/DSC02442.jpg
the hose goes down to the other side of the block. my best guess is a coolant hose but i really have no clue
http://i573.photobucket.com/albums/s...2/DSC02443.jpg
close up
http://i573.photobucket.com/albums/s...2/DSC02446.jpg
and then there is this thing.... it comes off of a plastic tee on the bottom left of the picture. i dont know whats supposed to connect to the tee or where this hook shaped hose is supposed to go either.
http://i573.photobucket.com/albums/s...2/DSC02447.jpg
http://i573.photobucket.com/albums/s...2/DSC02448.jpg
i just know it comes down and around to the back of this thing which is to the right of the bell housing
http://i573.photobucket.com/albums/s...2/DSC02451.jpg
http://i573.photobucket.com/albums/s...2/DSC02453.jpg
EIPtuningR32 05-02-2009 09:39 AM
and also... what is this thing and where the hell is the hose??
http://i573.photobucket.com/albums/s...2/DSC02455.jpg
MPDano 05-02-2009 09:43 AM
Looks like your missing your Diverter Valve. This valve runs air to your airbox or exhaust. The vacuum line is what controls the valve.
MPDano 05-02-2009 09:47 AM
This thread may help. I can't seem to find a pic of mine.
http://forums.pelicanparts.com/porsche-928-technical-forum/454066-need-help-understanding-ob-smog.html?highlight=diverter+928
EIPtuningR32 05-02-2009 09:55 AM
you mean i am missing the actual diverter valve, or its not connected to anything...
EIPtuningR32 05-02-2009 09:57 AM
Originally Posted by MPDano (Post 4640296)
NICE THREAD!!! where is the decel valve located at?
ice-hot 05-02-2009 12:08 PM
Clutch slave cyl. No hose, bleeder screw. A good thing-- one less hose to worry about!
EIPtuningR32 05-02-2009 12:10 PM
YEAH!! i love good news
EIPtuningR32 05-02-2009 12:11 PM
anybody have any idea what that thicker hose it??
ice-hot 05-02-2009 01:30 PM
Looks like Air injection and Tank ventilation circuits. MPDano is right--something is missing! Maybe this will help? Happy hunting!
Johnhttp://forums.pelicanparts.com/uploa...1241296181.jpg
http://forums.pelicanparts.com/uploa...1241296227.jpg
Danglerb 05-02-2009 01:42 PM
Most of those bigger hoses will have a Porsche part number, makes for easy ID.
Hose in question looks to be #24 in the upper diagram, and all that stuff below it appears to be missing and needs replacing or figuring out how to do without.
MPDano 05-02-2009 02:11 PM
That bad boy is gone, missing, nada, kaput. I will take a pic of mine and show you what it should look like.
MPDano 05-02-2009 02:43 PM
Here you go. It always helps me better to see actual pics rather than diagrams. Puts into better perspective. You should also have a long tube going across the passenger cam cover to a host that goes to the Smog Pump.
http://forums.pelicanparts.com/uploa...1241300499.jpg
http://forums.pelicanparts.com/uploa...1241300505.jpg
http://forums.pelicanparts.com/uploa...1241300510.jpg
http://forums.pelicanparts.com/uploa...1241300516.jpg
http://forums.pelicanparts.com/uploa...1241300522.jpg
ice-hot 05-02-2009 02:57 PM
MPDano-That engine looks great! Where did you get the blue Plenum intake couplers? All I have seen is red.
Any problems running with the exposed TB? Looks nice!
John
And the blue air intake couplers?
MPDano 05-02-2009 03:33 PM
Exposed TB is fine so far. I only got about 400 miles on her since I got it running. The Blue Silicone Couplers were one single hose and I cut them down to size very carefully with an exacto knife. They work great. Lot's of choices in colors too.
EIPtuningR32 05-02-2009 09:04 PM
WHAT THE HELL?? do i "need" all of that? i live in Florida not Cali. no smog devils here. but i mean i now know i dont have them, but i also now know that at once it did cause its just ripped out of there.... the car runs good, i think. and i havent noticed any problems besides the whole damn thing..... could i just jerk all of the rest of the smog stuff that wasnt removed before? like all that hosing... what they go to if it is smog related, take the smog pump off if i have one... blah blah blah..?:confused:
MPDano 05-02-2009 09:17 PM
If you don't need smog in your state, just block the hose and vacuum line.
EIPtuningR32 05-02-2009 09:19 PM
ok?... its that simple? no removal of lines or parts?
american-kiwi 05-02-2009 10:39 PM
Before you fix the missing smog hose parts etc....take a look those 2 fuel lines!!!!!....in pictures 1/2/4
my oh my, there'a a fire waiting to happen!...i had to do mine too :-)
I started my car up the other day....a buddy of mine says...."whats all that fluid leaking under your engine?!!"....holy cr@p!!...a gas leak...and a bad one too!
EIPtuningR32 05-03-2009 01:39 PM
haha yeah.. i bought some more line today but its for that 9ft long line that runs from (i think) the gas tank to something on the front of the car... i think its the breather line that brings gassy air to a charcoal thing that filters fumes from air in gas tanks so it doesnt blow up:D
american-kiwi 05-03-2009 05:04 PM
its the two rubber hoses coming from those two steel lines just in front of the airpump hose you were asking about....the ones with the large cracks all over them, they have 19mm/17mm fittings...one is the high pressure line feed to the fuel dist'...the other one is a return line...by the looks of those hoses, one touch or bump...and their history...i see one has already opened up!..look at photo #2!...their both about 5-7 inches long...so when the engine moves with torque they can flex
EIPtuningR32 05-03-2009 05:25 PM
oh yeah those... i disconnected those at the top to see if i could get to the manifolds easier and they just like dissintigrated =/
