Cheap A/F gauges and stock O2?
I found this Air Fuel ratio gauge on Amazon for $22 (ships free at $25), so I added some filler and bought one. Anybody using one of these cheap gauges with a stock O2 sensor?
http://www.amazon.com/gp/product/B000FJQWS0 |
Mike,
Weren't you of the ones telling me that a narrow band O2 reading ain't worth s%$t? Anyways, did a bunch of research on this and came to conclusion that I really need a Wide Band O2 Sensor and a Wide Band A/F Gauge. You can find them for around $200 as a set. |
Yeah, I thought Mike was beating that drum with me. At that price point I wouldn't expect much.
Leo doesn't run closed loop with his O2 sensor, which I think is key to one of these working.
BTW I have a wide band O2 sensor, but saving it to use when I borrow a wide band meter. |
I'm not sure, but my conjecture is without closed loop control its going to show rich or lean, without a good indication of how much.
I don't plan to mount this one in my car, just hook it up for some amusement and then it can go into a different car. We can give it a try in Leo's car and see what it does. *** If your question is about using a wideband sensor with a narrow band meter? The output of the wideband slowly changes voltage from lean to rich, and the narrow band doesn't change voltage much until a "trigger" point at stoichiometric where it changes abruptly. Unless a meter is calibrated for the sensor curves the voltage won't mean much. |
Test away. The O2 wire terminates to the Center Console to nothing. Go for it!
This is the one I was talking about getting when the funds exist.
http://i4.ebayimg.com/01/i/000/f6/3c/ae6f_1_sbl.JPG |
Unless you are running boost, why would you want one?
On my my 85 Euro I intend to sharktune it, and I don't think the Sharktuner on the LH2.2 can pick up A/F directly. For the other cars, just curious, maybe try some tuning with the more limited controls.
Oil temp is fun, literally hotter the oil the more fun you are usually having.
