-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Central locking trouble 1988 S4 (http://forums.pelicanparts.com/porsche-928-technical-forum/474915-central-locking-trouble-1988-s4.html)
supervc10 05-17-2009 08:05 AM
hello to my fellow 928 owners, as spring arrives here in michigan, I have been busy getting my car on the road, I had a body shop repaint the door, in doing so they shorted some wire together that controlled the windows and the mirrors, I replaced the fuse and everything seemed to work ok, but now the door lock systems works with only with the key, and no longer works with the button on the console, is there a separate fuse for the central lock system? where is the central lock system? any idea's would be most helpful, thanks to all that respond!
Danglerb 05-17-2009 11:35 AM
Two 0.5 amp fuses just above the central electric panel.
