How do i take off my dashboard ?
hi i am trying to put in a new light switch in my car and need to take off my dashboard does anyone have photos or know of a website that does ?:confused:
Where are you actually putting the light switch within the dash. You could probably remove most other things without actually removing the dashboard.
to replace a light switch you should'nt need to pull the dash/pod....just pull the rubber cover off the switch...then with two little screw drivers pry the pins inwards on the switch and pull it from the dash pod...then remove the connector on the back...done..easy
watch these vid's...he does it on there... it was part 4 you need to watch..but there neat to watch.. http://www.youtube.com/watch?v=qPQ2_CHNvgo&feature=related http://www.youtube.com/watch?v=pwnZaNHIeWo&feature=related http://www.youtube.com/watch?v=G4Jz3ure7-E&feature=related http://www.youtube.com/watch?v=XtkXkfUca1o&feature=related http://www.youtube.com/watch?v=OB5ORJtEoQk&feature=related |
thank u soooo much that saves me soooo much time and thank u for the videos
i just got done watching it that was so simple how did i not see that thank u soo much
| All times are GMT -8. The time now is 04:42 PM. |
