BB500's Avatar
4.5 to 5.0
I was just wondering (no plans to do it)
Would replacing the block from a 4.5 with a later 5.0 block, just block not heads, change the displacement to 5 liters? I'm sure someones probably done this. I was just wondering because I have a 91 complete engine lying around... I'm more than likely going to just sell the 91 engine because the 4.5 only has 48k on it...
But still curious if power would increase.....
Old 06-04-2009, 07:58 AM
Network Native
Danglerb's Avatar
Your S4 block would be a MESSY and expensive swap, but a hybrid motor with an early Euro top end would drop in quite nicely, and to any but a very experienced eye look entirely stock and pass smog.
A stock early (80 to 83 CIS) Euro S motor would also work, but using the larger bore of the 100mm 5.0L 85/86 block works best.
What makes it simple is you keep the same style of injection that is already in the car. Many of the Euro S parts are different, so before you order up replacements you should decide on the direction you want to go in. I know the WUR is different, not sure on the fuel distributor, which I think is the same for all cis 928.
Old 06-04-2009, 11:23 AM
