Alarm issues
I have a weird problem with my '88 S4. Every once in a while the car won't start, everything energizes when I turn the key but the start doesn't turn.
I check relays and narrowed it down to the alarm system, I can disconnect the battery and it re-sets itself and everything works fine for a while. I suspect a faulty Alarm control unit (behind the glove box). I want to by-pass the factory alarm to confirm my suspicions. The factory repair manual states; " Pull off plug Z on the central electric board and bridge terminal 1 and 6 on central plug, this will disable the alarm" Anyone know where this plug Z is located? thanks |
All the plugs on the central electric panel have a letter ID, guessing Z is one of them.
I thought factory alarm was crank and no fuel? |
yes..all the plugs are lettered A-Z in the pass' side footwell
Thanks, I'll have look for the plug in the fuse panel.
The alarm does not disable the starter - look elsewhere - probably in the starter circuit - most likely the park interlock (neutral safety) switch.
Alan |
My S4 is a manual, I didn't realize that the 5 speed cars have a park neutral switch?
When I re-set the alarm system the car starts everytime. I've checked and replaced the starting circuit relay with no difference....but I'll investigate further. Thanks |
Manual Transmission cars do not have a neutral safety switch (I assumed AT since you didn't say and it the most common) - but they do have all the wiring for one (so there is just a jumper where it would connect in the area above (and forward of) the battery box.
You don't have a "Z plug" those directions are for a <'85 vehicles. You can link CE pins B23 & F25 to defeat the alarm disable feature - however this really only affects the LH & Fuel pump functions (not the starter) - however you can verify if this solves the problem (maybe someone messed with something?) Alan |
Thanks Allan,
Every bit of information helps. It's strange that somehow the starter becomes dissabled but I can still drive the car if I roll it and do a "bump start". Everything I've checked points to an alarm system malfunction but now you have me thinking...I'll be re-checking the starting circuit again. |
