cam gears
doing a wp and tb change, also changing both cam gears. my question is, after i removed the bolt holding the left side gear on, i got a small drip of motor oil coming out of the bolt hole. also the bolt was wet with oil. but on the right side all was dry. no oil on the bolt or leaking out the bolt hole. is this normal? am i ok to install new gears.
Old 07-21-2009, 03:21 PM
Petie3rd
Mrmerlin's Avatar
OK need more info , Location,year , model, and be specific on the left and right . try using driverside and pass side
Old 07-21-2009, 07:27 PM
Petie3rd
Mrmerlin's Avatar
just from the info it sounds like there is porosity in the cam or its cracked, there should not be any oil in the bolt hole.
But really need more info as if its an early car then it has distributor drive on the driver side of the engine
Old 07-21-2009, 07:29 PM
vdubr928's Avatar
Maybe someone was in that side and dipped the bolt in oil before reassembly. Could be nothing. Don't get too excited. I always dip major engine bolts in a little oil. Something an old Mercedes mechanic taught me when I was a kid.
Old 07-22-2009, 07:54 AM
it's a 1982 US928. driver side, the cam with the distributor on it. sorry about that lack of info. Thanks Jerry.
Old 07-22-2009, 11:41 AM
Agree! The oiling journal is too far back for a crack to fill the bolt hole with oil.
Dennis
Dennis
Old 07-23-2009, 06:22 AM
Heavy Metal Relocator
rhjames's Avatar
16V cams are known to have gear end breakage, so.....
if the oil is in fact coming from a crack in the cam itself, you might have the cam magnafluxed/checked for cracking---just to be sure.
if the oil was put on there during prior assembly, then you should have no worries.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 07-23-2009, 08:30 AM
